Convert Points to Lines
  • Dec 9, 2014 8:19 AM UTC
  • 10 replies
  • 1033 views
Dear FME community,
perhaps there's an easy solution for this:
Is there a way to convert dataset of points to lines? The lines need only to be a few metres long, and the orientation is not of interest at first. Something of a PointToLine transformer...?
Kind regards
Thomas
  • Dec 9, 2014 8:32 AM UTC
look at the PointConnector or the VertexCreator.
David
  • Dec 9, 2014 9:33 AM UTC
Thanks David!
The PointConnector did the trick. The distance between the points can be adjusted in the Offsetter.
Kind regards
Thomas
  • Dec 10, 2014 4:24 AM UTC
Good work, Thomas.
Another way.
If you are going to create line segments whose start node is the original point and end node should be offsetted from the point, the VertexCreator (Mode: Addd Point) can also be used effectively, as David mentioned first.
Assuming that the offset amounts are x = 1.0, y = 1.0:
@X/YValue function extracts the value of the first x/y coordinate of the feature.
FYI.
Takashi
  • Dec 10, 2014 8:29 AM UTC
Thank you Takashi.
Works like a charm. Just one transformer is of course more efficient.
Kind regards
Thomas
  • Nov 2, 2020 2:31 PM UTC
where is the answer? I cant see it?
  • Nov 2, 2020 2:38 PM UTC
Did you click the "expand post" link at the end of each reply?
  • Nov 2, 2020 3:48 PM UTC
Cheers! Not used to forum just yet!
  • Nov 2, 2020 3:50 PM UTC
No worries, not a fan of that particular functionality either...
  • Nov 2, 2020 3:56 PM UTC
CaptureOn the offchance do you know how I could convert these 4 simple points into a polygon?
Angle Range Intensity X Y Z
340.7656236 2.64199996 1008 0.870362491 -2.49452058 0
341.0000084 2.65199995 1008 0.863406364 -2.507515341 0
341.2812482 2.657000065 1008 0.85269237 -2.516458835 0
341.5624881 2.625999928 1008 0.830525534 -2.491205121 0
Sort of thing I've tried is above image:
  • Nov 2, 2020 4:04 PM UTC
The easiest is proably to chain 4 VertexCreators one after another (one per vertex). Configure the first VertexCreator to use mode "Replace with point", the following with "Add point". Adding points to a point geometry will automatically convert it to a polyline. Finally, add a LineCloser to close the line and convert to a polygon.
