Compare and filter out line with shorter length
  • January 14, 2016
  • 131 views
I have duplicate line segments with same unique ID but different lengths. I would like to filter out the shorter line and keep the longer line for further transformation.
Best answer by jdh
Calculate the length, sort your features by length and then use a sampler (First 1 feature), grouped on the Unique ID attribute. The longest lines will be from the sampled port, and the shorter duplicate lines will be sent through the unsampled port.
Alternately use a DuplicateRemover in place of the Sampler.
jdh
Forum|alt.badge.img+40
  • January 14, 2016
Forum|alt.badge.img+46
  • January 14, 2016
If you sort by unique ID and length in desc order then use a duplicate remover, FME will output the longer line via the unique port.
  • January 14, 2016
Thank you !!
  • January 14, 2016
Thank you.
