Can't find "Format attribute set: powerpoint_hyperlink" under the powerpoint styler transformer
  • Feb 4, 2020 6:39 AM UTC
  • 84 views
felipeverdu
Forum|alt.badge.img+12
Hi
It seemes to me that I Can't find "Format attribute set: powerpoint_hyperlink" under the powerpoint styler transformer.
I need to add a hyperlink in a powerpoint slide. Under the help text, it states that is one of the parameters.
I am using FME(R) 2019.1.3.1 (20191019 - Build 19643 - WIN64)
Best regards,
Felipe Verdú
debbiatsafe
Forum|alt.badge.img+24
Hi @felipeverdu1
Yes, it appears the Hyperlink Address parameter is documented in the transformer documentation but is not available within the transformer. Thank you for letting us now. I will file an issue to get this issue fixed.
If you want to add a hyperlink to your text, I would recommend using the Powerpoint format attribute powerpoint_hyperlink. I've attached an example workspace demonstrating this approach. powerpointhyperlink.fmw
felipeverdu
  • Feb 6, 2020 11:42 AM UTC
Hi @debbiatsafe
I tested your workspace and it worked out right.
I tried to apply yours in mine but it still fails
I have attached an example workspace of what I am trying to do.
hyperlinkfails.fmwt
debbiatsafe
Hi @debbiatsafe
hyperlinkfails.fmwt
Try creating the format attribute after the PowerpointStyler as in this example workspace HyperlinkFails_safeSupport.fmw
felipeverdu
  • Feb 7, 2020 7:10 AM UTC
That was the solution! Thanks a lot! no right forward I might say!
