Adding Measurement as line on the Road Network
  • Jan 12, 2021 11:21 PM UTC
  • 75 views
I want to add from excel file start and end point that are in Meters, to the road network(which is complex) and create line from it. attaching sample shapefile and excel file. Join field is RoadName.
Does anyone solved such case? All suggestion will be very helpful.
Thanks a lot.
danilo_fme
Forum|alt.badge.img+58
  • Jan 13, 2021 12:12 AM UTC
Hi @gisgis2014devel​
To replace a point you can use the transformer VertexCreator and for do a Join between value of attributes, you can use the FeatureMerger.
Thanks in Advance,
Danilo
DanAtSafe
Forum|alt.badge.img+23
  • Jan 13, 2021 12:34 AM UTC
Hi @gisgis2014devel​ As you say, your road network is quite complex. If it was just three lines - B1, B2 & B3 then the next step would be to add measures with a MeasureGenerator, then join the Excel data as @danilo_fme​ suggested, and finally create the lines with a Snipper. If you could identify the ends of the lines then you could use a ShortestPathFinder to create a single line from the input features. Or if accuracy isn't necessary then you could buffer each road and then use a CenterLineReplacer to recreate it. But even then you will still need to determine which end is the start of each road. Hopefully you have some other data for that.
Hi, thank you for your reply. No I don't have other data.
