2d point replacer
  • Apr 16, 2014 3:40 PM UTC
  • 105 views
Okay so I see a lot has changed since I was last in FME.  I have an ESRI file geodatabase table that contains X and Y data adn I want to create a file geodatabase feature using that data.  In an older version I used 2d point replacer but it seems that transformer is no longer available.  I am also having trouble with my installation of FME 2014 SP 1 not giving me any help topics.  Any suggestions on how to complete this task.
Hi Jim,
Use the Vertex Creator (http://docs.safe.com/fme/html/FME_Transformers/Default.htm#Transformers/vertexcreator.htm) transformer.
Also you should be able to start typing on the FME canvas and by typing 2DPointReplacer it will "recommend" the Vertex Creator instead.
Matt
  • Apr 16, 2014 4:34 PM UTC
Thanks Matt.  I forgot about the trying on the canvas trick.  Very Helpful.
