Generate points with raster constraints
jdh
Forum|alt.badge.img+28
I have a coarse raster where the pixel value indicates the number of points that should be generated within the confines of the pixel.
I have a fine raster (1 to 2 orders of magnitude higher resolution than coarse raster) where the pixel value indicates whether a point can be placed there. For simplicity purposes this can be a binary mask.
I would like to generate points according to these two rasters with the additional criteria of a minimum separation between points.
Thoughts on how to do this in an efficient manner? I'm hoping to avoid the brute force approach of generating a random point, checking the constraints and repeating until the desired number of points is reached.
Best answer by jdh
I ended up solving this by taking advantage of the fact that the python raster API requires you to specify a tile in order to retrieve the rater data.
Looping through each pixel in the coarse raster I created a tile in the fine raster corresponding to it's boundaries. Converted the tile to numpy flat non zero array, then used random.choice to select the number of elements based on the coarse raster value, then determined the coordinates of the center of the pixel of those elements and exported them as points.
  • February 18, 2020
Depending on your constraints, I would perhaps try something like:
  • Coerce the binary mask to points, but only where the pixel value = "True". Nodata may be useful for this.
  • Coerce the coarse raster to polygons and overlay the points to check for number of overlaps, i.e. if you need to create or remove points.
Negative side is that coercing rasters to points/polygons is fairly slow in FME, so if the rasters are large and you need to be quick, you may want to look for an alternative.
Otherwise I've had great success so far using the fmeobjects raster support to do stuff in Python. If you convert the rasters to numpy arrays you get great performance.
jdh
  • February 18, 2020
Yeah, I'm hoping to avoid coercing the raster to polygons as the expected size will be 37000x35000 pixels. I can chop it up into pieces to avoid memory issues, but vectorizing the raster is painfully slow no matter what.
  • February 18, 2020
Ooof, agree that's way too big for vector conversion.
jdh
  • February 18, 2020
I'm thinking numpy as well, and thensome sort of random population extraction from the mask. But I have no idea how to subset the pixels based on the coarser raster (other than the aforementioned convert to polygons)
jdh
  • February 24, 2020
  • February 24, 2020
Nice! But will it be on the exam? ;-)
But seriously, I'd go watch that presentation.
jdh
  • February 24, 2020
This ran in 30s as opposed to the coerce to polygons approach which I killed after 6 hours.
  • February 24, 2020
That is really impressive performance.
jdh
  • February 24, 2020
Numpy for the win.
jdh
  • February 24, 2020
I did need to write a couple of helper function to convert between pixel space (rows/cols) and real space (lat/long) as that's not part of the api.
  • February 24, 2020
That sounds very familiar. I've been doing quite a bit of FMERaster stuff lately as well. And yes, numpy arrays are amazing.
jdh
  • February 24, 2020
Are you as aggravated by the tile concrete classes vs abstract classes as I am?
  • February 25, 2020
I am, but my biggest issues are cryptic or non-existing error messages when you do something wrong (not that we're spoiled with examples), difficulties in debugging Python code in FME (I'm looking at you, FMEBandTilePopulator!) and this weird thing where you're not allowed to assign integer values to bands containing floats (not very ducky-typey). Also it bugs me that Safe haven't fixed the small documentation errors that were flagged by Takashi more than a year ago.
jdh
  • February 25, 2020
Ah yes, the non-existent error message, I know it well.
