Cannot update XML-file using XMLUpdater when XML input is more complex
  • August 18, 2018
  • 5 replies
  • 103 views
friesewoudloper
Participant
My aim is to update the creation date in the metadata of a feature class in ArcSDE using XMLUpdater.
However, with the workspace I've build so far, the value is not changed.
At first I thought I might have the XML path wrong. But I did some testing and found that when I simplify the XML (leave some nodes out that are further on in the XML file) everything works fine.
So my attached workspace works fine when I use the attribute geodb_metadata_string_simplified as the XML input, but it doesn't when I use geodb_metadata_string. Do you know what might cause this problem?
  • August 19, 2018
Hi @friesewoudloper, I was able to reproduce the symptom, with FME 2018.1.0.0 build 18520.
In my observation, the XMLUpdater seems to consider the default namespace "http://www.isotc211.org/2005/gmd" which is declared in the "MD_Metadata" element as the default namespace across the entire XML document. If my observation was correct, it would be a bug. Could you please check this? > @DeanAtSafe
A workaround in the interim, you can use the XMLXQueryUpdater instead.
XQuery Expression:
replace value of node /metadata/Esri/CreaDate with '20180818'
  • August 19, 2018
XQuery Expression:
This workspace illustrates what's the issue on namespace handling in the XMLUpdater.
b18520-xmlupdater-issues-repro.fmw (FME 2018.1.0.0)
  • August 19, 2018
XQuery Expression:
Another workaround. The prefix "*:" resolves any namespace, so this XPath set to the XMLUpdater works as expected in this case.
/*:metadata/*:Esri/*:CreaDate
friesewoudloper
Participant
Thank you very much @takashi!
I have the problem in FME Desktop 2018.0.0.2 (20180414 - Build 18301 - WIN32).
I have a second question: I'd like to generate the xpath dynamically based upon a column ('Attribuut') in an Excel file. However, when I choose this attribute in the text editor for the XML Path, the generated code is wrong. It is:
//*:featureAttribute[*:name/text() = 'fme:get-attribute("Attribuut")']/*:definition
where it should be:
//*:featureAttribute[*:name/text() = '@Value(Attribuut)']/*:definition
I can change this myself and everything works fine. Is this also a bug, or does FME generate the xpath as one might expect? Is it something I do wrong?
friesewoudloper
Participant
where it should be:
I'm sorry, I should probably post my second question seperately. I will do so.
