SQLExecutor Stored Procedure with return value
  • July 14, 2021
  • 200 views
Folks, we are trying to call an Oracle Stored Procedure using SQLExecutor that send the student information and it return student_id back to FmE to be used in subsequenct translations. any idea how to do it in FME.
store procedure name
intsertStudent(name,address,class) return student_id.
Apprciate your help!
  • July 14, 2021
Try something like this:
select insertStudent('@Value(student_name)',
  '@Value(student_address)',
  '@Value(student_class)') as "student_id"
from dual
This assumes that you have the attributes student_namestudent_address and student_class entering the SQLExecutor. You should get one feature back with the attribute student_id, which you'll have to expose manually in the SQLExecutor.
from dual
Thanks David,  this technique does not work when your function is performing DML operations. Error i got from FME
did not succeed; error was `ORA-14551: cannot perform a DML operation inside a query
nampreetatsafe
Forum|alt.badge.img+13
I'm wondering if the solution @david_r​ suggested in this post would work in your case: https://community.safe.com/s/question/0D54Q000080hKDTSA2/results-from-oracle-stored-procedure
