HTTP call JSON parsing problem
I have a problem with parsing JSON which is the result of an HTTP call to get what I need. (See json files attached.)
If I download the .json file and simply put it in a JSON reader with a query,
filter for type:"Update Feature Attributes" and explode some of the lists, it gives me what I need:
My problem is that I have loads of transactions to go through the same way, so I'd need to use an HTTPCaller. I've managed to get that far that with a JSONExtractor I can get "type", "ID" for example, but struggling to break down lists "attributesAfterChange" and "changedAttributesNames" - ListExploder doesn't recognise them as lists for some reason.
Any ideas what should I do to get the list values/break down the arrays? Maybe it's very simple but I just cannot find a solution right now. NB: the attributes in these lists vary and not exclusive to what's in the attached json files, so somewhat making it a bit more complex...
Any help is very much appreciated, thanks in advance.
Zoltan
Best answer by nathanatsafe
Hi @zkovacs,
Depending on how the rest of your workspace is built and how you construct your HTTP calls, one option might be to use the FeatureReader instead of a combination of HTTPCaller and JSON transformers. In the FeatureReader you can set the format to JSON or GeoJSON and use a URL for the source dataset parameter (this could also be an attribute or a string built from attributes using the text editor. This might save you some steps.
Hope this helps.
Best,
Nathan
Hi @zkovacs,
When you set up the list attributes to be exposed in the JSONFragmenter are you including the curly brackets {} ?
nathanatsafe
Forum|alt.badge.img+7
  • August 23, 2018
Hi @zkovacs,
Hope this helps.
Best,
Nathan
  • August 28, 2018
nathanatsafe wrote:
Hi @zkovacs,
Hope this helps.
Best,
Nathan
Hi Nathan,
Thanks for the tip. Unfortunately I cannot use a FeatureReader as I need to know if a request to the API I'm calling was successful (HTTP 200) or not, so I can set up a loop to keep trying until I get all the transactions I need.
I set up an HTTP Caller with a loop to do this and it generally works OK (apart from the minor issue of trying to break up the mentioned arrays/lists) but for some reason, some of the features are 'objects' instead of 'json_line' and I cannot figure out why...
I've attached the fmw file and the csv containing the transaction IDs, could you have a look and see if you can find out why some of the features are objects? I had a look at the response and I couldn't see anything in particular that would be the cause.
Thanks,
Zoltan
[attachments removed]
  • August 31, 2018
I've managed to work around the issues I had by downloading the .json files from the API using a Python script I wrote and then did the rest of the workflow in FME.
