planet data reader - standalone or needs to be used with other transformers ?
pat_uow
Hi there,
Just wondering if this transformer can work standalone ?
I've got my api key and filled in what I think is an appropriate search envelope in LL84. Just not sure if Planet's imagery covers what I'm after on the east coast of NSW Australia.
Any other way of doing a quick check ?
Thought there was also a beta version in FME server that was demo at the World Tour - but haven't been able to find it.
Thanks
@pat_uow This article discusses thePlanet, Sentinel and Landsat readers so it should give you a start. It is part of a tutorial on working with satellite data in FME.
You're correct, we did have a demo for the FME WT17 using some of the free Planet data for California. I've attached the workspace. planet-reader-demo-2017-1.fmw
I think Planet Explorer should be able to tell you if there is imagery for your area of interest
pat_uow
  • July 3, 2017
Thanks @MarkAtSafe,
I have tried both the planetdata reader and the featurereader with the expected parameters and a valid API. The readers appear to be accessing available parameters similar to the ones in the tutorial referenced, but do not expose the "visual" feature type. All other types, e.g utm, analytic, thumbnail, etc appear to be exposed.
I can confirm that imagery for the area of interest appears to be available in the planet explorer (beta) as daily shots or monthly stitchups. A monthly stitchup for May 2017 for the AoI was seen with the search parameters below.
I'm sure the trick will be one of the parameter settings, I'm just not sure which one....
Any further clues on this would be appreicated.
https://www.planet.com/explorer/#/geometry/POLYGON((149.9372+-33.8065,151.4122+-33.8088,151.0729+-34.7923,149.929+-34.7923,149.9372+-33.8065))/items/PSScene4Band%3A20170701_232004_0e0f,....all of the images...../center/150.396,-34.355/zoom/10
pat_uow wrote:
Thanks @MarkAtSafe,
What version of FME are you using? The Planet API changed just after the FME 2017.0 release. Try installing the latest version of FME 2017.0 or the 2017.1 beta. OR, under the Planet Reader Parameters, try typing Assets: visual instead of using the the Select Assets list.
pat_uow
  • July 5, 2017
The current software installed is 2017.0.1.1 Build 17291.
pat_uow
  • July 5, 2017
Here is the latest attempt with 2 different setting of the planet data reader. Neither is returning anything.
@pat_uow In your URL it looks like you are trying to access 'Item Type' PSScene4Band. I don't think these Item Types have a 'visual' Asset. Check the Planet API docs for the types of Item Types and their corresponding Assets. In FME, if I choose Item Type PSOrthoTile then I can see the 'visual' Assets. In Planet Explorer, I couldn't find a way to itemize the list of items in navigator panel.
fmelizard
Forum|alt.badge.img+17
  • July 8, 2017
Changes were made in the remote sensing readers to make them play nicer with FeatureReader in FME 2017.1. If you're able to @pat_uow I'd suggest grabbing the latest 2017.1 beta from http://www.safe.com/beta and giving that a spin.
