Trial license lost in FME Desktop on Linux
  • November 19, 2017
  • 13 views
I installed FME Desktop 2017.1.1.1 under Linux and have obtained trial license code. It worked within that session. However, after I restarted the computer, FME asked for a license again. On Windows, there is no such issue.
Is this something expected? Any workaround?
Hi @crayxt
Did your registration key change? On some machines when they restart the key will change, which invalidates the licence.
This used to happen to me when I would start my computer with different peripheral devices attached. In virtualised environments or when someone installs to a network share this is more likely to occur.
I would request a new trial licence.
  • November 22, 2017
It looks like machine code changes on each reboot (cycling over 3 values). Does it matter if I unpacked Centos-7 version of FME Desktop 64-bit and use it on Fedora 27?
I have also 3 versions of kernel installed, is it somehow connected? I will cleanup older ones and will try to reboot couple times.
UPD: It looks like machine code change does not depend on installed kernels.
