I've found this documentation that mentions that comma should be surrounded with quotes when using in string functions. But the case now that I receive a file name (which contain comma) in a published parameter, then I want to replace part of the file path with some other string using "StringReplacer" function. I can't do this as the value retrieved in the published parameter has already the comma. Any Advise?
