HTTPCaller file post
nic_ran
Forum|alt.badge.img+16
I'm using the HTTPCaller to upload (POST) a file as well as some additional data. This is relatively simple when the file to be uploaded is sitting on the file system somewhere. Simply set the HTTPCaller Upload Data type to "Multipart / Form Data" and set the multi-part content for the file portion to point to the file on the file system.
However, my file content (not the path to a file) is already in an attribute on the feature. Does anyone know if I can get the HTTPCaller to upload a file in this way?
Nic
Best answer by nic_ran
Rylan at Safe Software support helped me out with this. Unfortunately, I wasn't able to get my particular use-case to work because it seems like there's a bug in the API that I'm trying to use. However, as a general rule, it should be possible to upload file content from an attribute in a multipart/form-data upload.
The HTTPCaller settings will look something like this:
The important points to note here being the "Content-Type" and "Content-Length" headers and the Upload Data being set to "Specify Upload Body".
The format of the upload body content will vary a little depending on the API you're calling but will be something like:
--<your boundary text>
Content-Type: application/json; charset=UTF-8
  "attr_name": "attr_value"
Content-Type: image/jpeg
@Value(_file_contents)
--<your boundary text>--
Hope this helps someone....
jdh
Forum|alt.badge.img+28
  • May 12, 2016
You should be able to set your Upload Data to Specify Upload Body and set the Upload Body to an attribute.
nic_ran
  • May 14, 2016
I've tried doing that but I think the HTTPCaller is overriding things behind the scenes.
I've set my Content-Type header value to multipart/form-data and my body is:
Content-Disposition: form-data; name="fileProperties"
@Value(_filePropertiesJSON)
Content-Disposition: form-data; name="fileContent"; filename="@Value(_pwFile_filename)"
Content-Type: text/plain
@Value(upload_file_content)
but the error that I'm getting back from the service that I'm calling is:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Header</h2>
<hr><p>HTTP Error 400. The request has an invalid header name.</p>
</BODY></HTML>
The only header value that I'm trying to set is Content-Type and its value is:
multipart/form-data; charset=utf-8; )
Ideally, what I would like is an option on the HTTPCaller to allow me to select the Upload Data type to be multipart/form-data and then to select the file contents part to be supplied by an attribute.
nic_ran
  • May 25, 2016
Forum|alt.badge.img+3
  • February 28, 2019
I just thought I'd provide some more insight to this issue, it took a savvy FME user, a pretty advanced web developer and searching many Stackoverflow solutions to get the HTTPCaller parameters to line up with Google Docs API documentation and come up with the solution.
https://developers.google.com/drive/api/v3/manage-uploads
https://developers.google.com/drive/api/v3/multipart-upload
https://developers.google.com/drive/api/v3/folder
https://stackoverflow.com/questions/12889532/insert-a-file-to-a-particular-folder-using-google-drive-api/12889786
https://gist.github.com/tanaikech/bd53b366aedef70e35a35f449c51eced#sample-script-2
This HTTPCaller writes an XLS file to a Google Drive folder and converts it to a Google Sheet. There are two required Query Strings: "upload", and "convert".
Three different Content/MIME types: Header "Content-Type" (above), metadata MIME Type, and media MIME Type.
Lastly the order of the Multipart Upload matters. I hope this helps others.
For the example you've mentioned, how do you attach an actual file right after line 10 (Content-Type: image/jpeg ) if it's not in an attribute?
