Extract Coordinates of a Surface on a 5 X 5 Grid
  • January 31, 2020
  • 24 views
Hello,
I have a 3D surface (mesh) and I am looking to extract point coordinates on a 5 X 5 Grid of this mesh.
A conceptual workflow in my mind would be:
Create a 5X5 Grid based on the bounding box of the surface (?)
Extract the coordinates of the points that are on the surface using a spatial filter
This is not much to start, but any suggestions would be welcome.
Thank you,
George
Forum|alt.badge.img+48
Yes, that sounds about right. BoudingBoxReplacer on the surface, 2DGridReplacer to turn that into a grid, SurfaceDraper to drape that grid over the original surface.
