Make a list of selected files in a directory
Hello,
I have to list files from a directory with the beginning of the name and then with this list I have to create an attribute. I wrote this and it doesn't work.
import os
import fme
import fmeobjects
path = 'C:/Program Files/Apache Software Foundation/Tomcat 8.0/webapps/ROOT/143/EvacEaux/Photo'
def processFeature(feature):
    photo = [i for i in os.listdir(path) if os.path.isfile(os.path.join(path,i)) and \
         '143EMC4501' in i]
feature.setAttribute('photo', photo)
  • March 28, 2017
Do you get an error message?
In your code the object "photo" is a list, but you try to assign the list to a regular attribute which expects a number or a string object.
You'll have to either concatenate your list into a string, e.g.
photo_str = ', '.join(photo)
feature.setAttribute('photo', photo_str)
or write the contents into an FME list, notice the brackets in the attribute name:
feature.setAttribute('photo{}', photo)
erik_jan
Forum|alt.badge.img+17
  • March 28, 2017
Why not use the "Directory and File Path" reader.
That reader gets you all the names (and paths) of the files.
Then use the Aggregator to create a list of the file names.
Seems like the result you need.
carsonlam
  • March 28, 2017
The FMEObjects Python API supports setting list attribute values without the curly braces:
>>> from fmeobjects import FMEFeature
>>> f = FMEFeature()
>>> f.setAttribute('foo', ['bar''baz'])
>>> f.getAttribute('foo')
['bar''baz']
carsonlam
  • March 28, 2017
From the script you've pasted, it looks like line 13 is sitting outside of the processFeature() method definition, so you may be seeing a NameError. Try indenting it one level.
Forum|alt.badge.img+7
Hi @lucie
@erik_jan already gave this solution but since there was no response I am positing it again with an example of the implementation. Is there a reason why you want to go for a python implementation while there is a straightforward FME implementation?
The Directory and File Path reader allows you to list all files and/or directories in a specific directory. You can even apply some sort of regex-constraint (e.g. all filename have to start with 'create' in the example below). The reader lists all the information available for the files found and allows you to aggregate all the path_rootnames (the filename without extension) into on attribute.
  • March 29, 2017
Thank you to everyone.
I will use directly FME implementation as @jeroenstiers has explained.
  • March 29, 2017
>>> f = FMEFeature()
['bar''baz']
Nice, thanks for the info!
Hi @lucie
Could you close your question If you've got an answer on it?
