Build polygon from others polygons
mr_fme
Forum|alt.badge.img+8
I have a workspace that I am attaching here . Its function is to cut the trails using the first network limit, now besides making this cut, I also need to cut the trails using park, but always creating polygons with the remaining cut parts.
P.S. all input file are DWG
In this workspace if I use only network works perfectly (see image), but if I enter the park layer, the following error below appears:
INDEX FAILURE - requested predicate not implemented
Why does it happen? Can you help me?
Thank´s
Best answer by takashi
Seemingly a single polygon for each location, but almost same two polygons overlap each other in fact. I think it's the reason why invalid geometries were generated.
This workspace example might help you: example.fmwt (FME 2018.1.0.3)
Forum|alt.badge.img+19
  • December 1, 2018
mr_fme
  • December 3, 2018
I'm very grateful for your attention.
You always help me a lot.
Thank you very much
mr_fme
  • December 3, 2018
@takashi,
One question, because you used the buffer with -0.5 in your workspace?
Thank´s
  • December 4, 2018
mr_fme wrote:
@takashi,
Thank´s
You could understand why the negative buffering was required, if you removed the Bufferer and run the workspace ;-)
