If it looks like tags are missing from your OSM file when read or viewed with FME, make sure the "Determine feature types by scanning the entire dataset" parameter is selected in the reader parameters - http://screencast.com/t/7R6QtBRv5.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
