Get Number of Concurrent FMEProcesses and FMEWorkerProcesses in Python
Hello!
One could access the maximum FME Processes and Workers in Python like this:
MaximumProcesses = fmeobjects.FMELicenseManager.getMaxFMEProcesses() or the same with workers.
How can I get the acual used number of Processes and Workers?
Thanks a lot! Regards Jacob
Best answer by david_r
Hi
You can use the subprocess module in Python and count the running instances of "fme.exe". Here's some info to get you started.
David
  • March 24, 2016
Hi
David
mark2atsafe
Forum|alt.badge.img+43
  • March 24, 2016
If it's after the translation you are asking for, could you try parsing that information out of the log file?
Thanks a lot!
I want to run a WorkspaceRunner and assign the "Maximum concurrent running instances"-Parameter dynamically at runtime by first checking the used instances (eg. 2) and depending on time and maybe a parameter (eg. one instance should always be accessible so 8-1-2 = 5 -> 5 instances could be used by the subprocess).
