How can I resolve "No module named arcgisscripting" resulting from a Shutdown Python Script in a workspace?
  • September 18, 2017
  • 73 views
My PYTHONPATH system variable is set to the following and python.exe and pythonw.exe are both in the D:\\apps\\Python\\ArcGIS10.5 folder. This script works fine in the Python window in ArcMAP.
D:\\apps\\Python\\ArcGIS10.5; D:\\apps\\ArcGIS\\Desktop10.5\\bin
jdh
Forum|alt.badge.img+28
Have you tried explicitly pointing the python interpreter to the arcgis dll?
courtney_m
Forum|alt.badge.img+5
Do you have the Python Compatibility workspace parameter set to ESRI ArcGIS Desktop, as shown in the following screenshot?
Also, make sure that your script begins with import arcpy.
