Merge single year mdb database to 10 years mdb database
Dear friends,
Please help me to merge two databases in single MDB, merge MDB file for winter 2019-2020 to winters 2009-2020 mdb database. I tried few options and it did not help much.
Also, I want to setup the system in task schedule.
Thank you.
Abzal
Forum|alt.badge.img+48
Can you give us a little bit more background?
Do you want separate tables per winter? Or just one big one?
What have you tried so far and why isn't it what you need?
  • May 4, 2020
Dear Friends,
Two mdb files, one mdb file is consisting of data for 2019-2020 and second mdb file has data for period 2009-2019. In result two databases should be merged. Merging process can consider also adding new features (classes) if created during the observations. I need one single database.
I have tried using database joiner transformer, however it did not give in result merged database as data were not added for winter 2019-2020 in single database 2009-2020.
Will try to watch more video online and gain experience, however if you have a better idea please share with me.
Thank you.
@redgeographics
Regards,
Abzal
