Why is the Visual Preview not showing data from selected Inspector?
Hello,
I'm wondering about data showing in the Visual Preview.
Below an example. Two flows of data going to two Inspectors.
When I select the SRC_RAW Inspector the Visual Preview shows the SRC_NORMALIZED data.
I will have to use the drop down menu in the Visual Preview to retrieve the SRC_RAW data.
That has annoyed me for quite some time now - why can't I just select the Inspector and see the proper data straight away?
Cheers,
Ed
Best answer by redgeographics
It's probably best to make an Idea for this and see if other people will vote for it.
Forum|alt.badge.img+48
  • May 14, 2020
Hi @edhere,
This is actually a known issue (FMEDESKTOP-9454), I will update this forum post when it has been fixed.
