How to mirror raster?
zzupljanin
Forum|alt.badge.img+4
Here's one of them brain foods...
How to vertically flip raster?
Right now, my idea is to extract numbers of columns. Tile whole raster by number of columns (RasterTiler), offset them by _columns-column_number and mosaick them (RasterMosaicker). And that works...
But that can be a really long proces (depending on dimensions of raster). Does anybody have any less time consuming idea?
Best answer by daveatsafe
Hi @zzupljanin,
The Affiner transformer can also mirror the raster, with the following coefficients:
A: 1
B: 0
C: 0
D: 0
E: -1
F: 0
Forum|alt.badge.img+19
  • July 31, 2017
Hi @zzupljanin, a possible way is to rotate 180 degrees with the Rotator and offset by (x = width, y = -height) with the Offsetter. The width and height of the raster can be calculated based on the extents extracted by the RasterPropertyExtractor (or BoundsExtractor).
daveatsafe
  • July 31, 2017
Hi @zzupljanin,
A: 1
B: 0
C: 0
D: 0
E: -1
F: 0
zzupljanin
  • August 1, 2017
daveatsafe wrote:
Hi @zzupljanin,
A: 1
B: 0
C: 0
D: 0
E: -1
F: 0
Yes, thank you. This one works like a charm.
These are coef for horizontal mirroring. For vertical are: A:-1 E:1 B,C,D,F:0
zzupljanin
  • August 1, 2017
Thanks, Takashi.
I don't think this is it. At least results aren't what I expected...
  • August 1, 2017
zzupljanin wrote:
Thanks, Takashi.
I was wrong, the Rotator won't make a mirror image. The Affiner is the way to go.
helmoet
Forum|alt.badge.img+8
  • August 1, 2017
Hi @zzupljanin, @takashi, @DaveAtSafe,
For georeferenced rasters you might want to put a BoundsExtractor before the Affiner and enter for parameter C the value:
@Value(_xmax)+@Value(_xmin)
(For the horizontal flip take parameter F and use the y values).
Like the attached workspace. This would compensate for the horizontal/vertical displacement of the transformed raster.
verticalflipgeoreferencedrasters.fmw
helmoet
  • August 1, 2017
On the other hand, why would anyone flip a georeferenced raster file :-)
Forum|alt.badge.img+48
I know some people who would be able to find a perfectly good reason to do that.
