Extract information from Web Page
danilo_fme
Forum|alt.badge.img+41
Hello all,
I'm try to extract a information from Webpage using the transformer HTMLExtractor, but i didn't a good result.
The Website is http://www.brasil.gov.br/ and the important information for me to extract is the href from this part of page:
Fale com o Governo
Attached my template file.
Thanks in Advance,
Danilo de Lima
Best answer by takashi
I sneaked a peek at the HTML source of the web page. There was no table tag, I think it's the reason why the error occurred.
You can get the HTML doc with the HTTPCaller and then parse the doc to extract the desired element. The HTMLExtractor might help you.
erik_jan
Forum|alt.badge.img+17
  • July 7, 2017
HI @danilo_inovacao
Have you tried the HTMLTable reader?
danilo_fme
  • July 7, 2017
erik_jan wrote:
HI @danilo_inovacao
Hi @erik_jan thanks your help.
My customer will not use the Reader. For begin the Workspace he 'll use the transformer Creator.
Thanks in Advance,
erik_jan
  • July 7, 2017
Thanks in Advance,
Can you use a FeaureReader with this format?
danilo_fme
  • July 7, 2017
I tried the use this transformer but a error happened.
mapping file Keyword: `R_4_+FME_DEBUG' occurs 5 time(s)
UniversalReader -- readSchema resulted in 0 schema features being returned
Failed to obtain any schemas from reader 'HTMLTABLE' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
Failed to read schema features from dataset 'http://www.brasil.gov.br/ ' using the 'HTMLTABLE' reader
The dataset 'http://www.brasil.gov.br/ ' was closed successfully
The 'HTMLTABLE' reader was destroyed successfully
Thanks in Advance,
Forum|alt.badge.img+19
  • July 7, 2017
  • July 7, 2017
The web page (HTML document) seems to be created dynamically by a JavaScript script. It could be hard to extract the element with the HTTPCaller + HTMLExtractor.
davideagle
Forum|alt.badge.img+21
  • July 7, 2017
I think that's the case. If you try to read the URL with the Text reader you get barely any content at all, something like 32 lines of HTML. So it appears to be a sub page that you might need to try to programmatically get to...
mark2atsafe
Forum|alt.badge.img+43
As far as I know, the HTMLExtractor won't read directly from a web site. The HTML has to come from a file, an attribute, or manually entered content. The Help doc suggests that and the error I get seems to confirm it:
'"%s" looks like a URL. Beautiful Soup is not an HTTP client. You should probably use an HTTP client to get the document behind the URL, and feed that document to Beautiful Soup.' % markup)
So your template will not work for sure. Instead add a HTTPCaller first and save the content to an attribute. But like @takashi says, I don't know if you'll get anything because the web page doesn't seem to want to return it. Maybe try a scraping tool to see if it's actually possible to get some data? Otherwise it seems unlikely FME will be able to do anything.
