WorkspaceRunner Error when runnging
  • September 5, 2019
  • 80 views
Please help to find out reasons for this errors. If i run job with cmd all ok. But WorkspaceRunner cannot run this fme job.
When running with WorkspaceRunner
FME 2019.0.2.0 (20190605 - Build 19260 - WIN64)
FME Desktop ESRI Edition (floating)
Permanent License.
Machine host name is: tcoatyv12gispro
Operating System: Microsoft Windows Server 2012 R2 Server 4.0 64-bit (Build 9600)
Copyright (c) 1994 - 2019, Safe Software Inc.
Safe Software Inc.
The environment variable FME_USE_LM_ENVIRONMENT is defined, causing FME to use the floating license environment variables LM_LICENSE_FILE and SAFE_LICENSE_FILE (if defined).
Shape Reader: Failed to open dataset which is neither an existing file nor directory
An error occurred during the batch file execution, 1 translation failed. The following error message was raised:
#2 : Shape Reader: Failed to open dataset
Program Terminating
Translation FAILED.
virtualcitymatt
Forum|alt.badge.img+34
Hi @bkolubenka,
It looks like there is something strange going on the with the file paths to the shape files.
You can see in the log that its looking only for one file, however, it looks like you want several files.
Each shapefile here should have a comma seperating the next shapefile and the beginning of each path needs to nave two slashes like I've shown below.
\\tcoatynas1\tcogis\browser\FGP\FGP_Primary_Network_Mons.shp\tcoatynas1\tcogis\browser\FGP\FGP_Secondary_Network_Mons.shp,\\tcoatynas1\tcogis\browser\FGP\FibreCable_Backbone.shp\tcoatynas1\tcogis\browser\FGP\FibreCable_Gathering.shp
Perhaps when running on the CMD you are only using one shapefile?
