How to set preference in FME workbench where one can set precedence:
How to set preference in FME workbench where one can set precedence: Step 1: (Run first) Data is downloaded successfully using HTTPFetcher, until it is complete the step 2 should not start. Step 2: (Run second) then a reader is used to read the above downloaded data. Currently having issue of step 2 start before step 1 is finished.
Forum|alt.badge.img+19
  • May 8, 2018
Hi @tareen_s, I think you can use the FeatureReader connecting to the HTTPCaller output.
  • May 9, 2018
Is it possible that you're using an older version of FME? The HTTPFetcher was renamed to HTTPCaller already in FME 2015. If that's the case you may want to consider trying a more recent version of FME to see if this behavior has been improved.
The HTTPCaller should not normally continue before the reponse has been fully received.
  • May 9, 2018
Thanks for your response. This script was created in FME 2014, I am currently running FME 2017
  • May 11, 2018
Try upgrading the transformer:
http://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Working_With_Transformer_Versions.htm
  • May 11, 2018
