Line to cylinder
  • February 17, 2017
  • 8 replies
  • 192 views
peteralstorp
Question time!
I have straight lines in 3D, oriented in many different ways, and I want to create cylinders (pipe). I do not want to use the 3DBufferer and I do not want to extrude a buffered slice. Is there another simple way of doing this?
Kind regards,
Peter
Best answer by david_r
Is there a particular reason for not wanting to use the two most obvious methods?
  • February 17, 2017
peteralstorp
  • February 17, 2017
Haha, good answer, David! I have collegues who argue that the 3DBufferer behaves strange at times and from there are limited ways to control the level of detail. But maybe they were doing something strange on their own!
From your question I looked into the possibilities with the Extruder. It looks good to me now. Should've looked into that sooner, sorry.
BUT, I would like to be able to get nice edges when I have a polyline with differently oriented segments and that's partly why I asked about other ways.
Forum|alt.badge.img+19
  • February 18, 2017
I think the solid created by the 3DBuffere looks very nice even if the input was a 3D polyline. What kind of edges do you want?
peteralstorp
  • February 28, 2017
@takashi, @david_r. Gentlemen, this helped me much, as always. I'm grateful for your help. Since Davids question made me realise wich way to choose I will award him with the correct answer. Thanks again. Peter
  • February 28, 2017
I'm honoured that my tongue-in-cheek answer was so well taken :-)
muzhnasto
Forum|alt.badge.img+12
  • October 8, 2020
11Hello? how did you make the straight end of the created pipe. How how to create a square tube?
Forum|alt.badge.img+31
  • October 8, 2020
I think that example may have been created by the Hub3DBufferer transformer, rather than the solid option in the Bufferer
muzhnasto
  • October 8, 2020
Yes thanks @ebygomm​ , found, and updated the question)
