When writing to Excel I would like an option to set a range (referencing the template file & Feature Type sheet) that will set default values and formatting for each new row FME will write.
Use cases are:
- Sheets where you have to click a button to add 5 more rows of template/formatting
- Sheets where the first 20 rows are formatted but we have more rows to write
How it could look:
In "Sheet Settings"
property: "Row Template Range" values: A12:XX12
Result:
- formatting
- values
- lookups
- etc...
Possibly related to
