Search For Attachment in AGOL
canerakin
Forum|alt.badge.img+5
Hi I am trying to find the features that has attachments.
So far I tried Tester and ListSearcher but I couldn't get any results.
Tester Parameters:
Left Value: arcgisonline_attachment{0}.content_type
Operator: Attribute Has a Value
ListSearcher Parameters:
List Attribute: arcgisonline_attachment{}.data
Search Type: First to contain regular expression
Search For: .
(also tried ^$)
Best answer by rahulsharma
Hi @canerakin​
Confirm that the Include Attachment is set to YES
Navigator Windows --> Feature Type --> Include Attachments
Then use ListExploder, and select arcgisonline_attachments{}
 This should filter is there is any attachments on the Feature service
virtualcitymatt
Forum|alt.badge.img+34
Hmm, really strange. I would have assumed that your tester option would have worked. And you're sure that the list attribute is present in some of the features?
If you are sure it sounds like a bug and I would contact SafeSoftware in Support.
rahulsharma
Forum|alt.badge.img+10
  • August 11, 2020
Hi @canerakin​
