FME Desktop 2020: Deaggregating the result of clipper tool produces extra unexpected polygons,
jamal
Forum|alt.badge.img+5
I’m wondering why deaggregating the inside result of the clipper tool produces extra unexpected polygons. I’m expecting to have exactly 8 polygons while the result is 12
What could be the issue here?
The workbench and the dwg file are attached
Clip_1052Clip_1053Clip_1054
Clip_1055
DanAtSafe
Forum|alt.badge.img+18
  • November 1, 2021
Hi @jamal The Clipper won't create aggregates if you set the Tolerance to 'Automatic'.
mark2atsafe
Forum|alt.badge.img+43
  • November 5, 2021
Hi. This works fine for me in 2021 and I think it should in 2020 as well, so it looks like you are using an older workspace in a newer FME. You need to update the Clipper and - as Dan says - set the Tolerance parameter to Automatic. Then you'll get 8 features and no aggregates.
Basically the Clipper's behaviour has been improved since the one you have placed in your workspace.
jamal
  • November 20, 2021
Thank you guys for the help
