Hi, I would like to find out how to best implement the attached workflow by using the most efficient means possible. I currently have a working model, but I designed it over 6 years ago. I believe it's outdated and would like a more efficient one.
The aim is to use the current transformers that FME has to offer.
Any help with this is much appreciated.
Thanks,
Sam
Be the first to reply!
