I got a set of 235 points and I need to cluster them, but based in two parameters. I need to spatial optimizer them in clusters of max 5 points and maximum distance between them of 15 km or in groups with less them 5 points and maximum distance between them of 15 km.
I am trying to use a NeighborFinder approach, but I got strugle into points that could be in on or more clusters and because of this, I don´t know how to optimize them.
Any ideas or tips?
Best answer by markatsafe
@rodrigo_ferrao I don't think NeighborFinder will work for you in this case. FME doesn't really have a density clustering algorithm. I think you'll probably have to look for some 'R' or Python tools that would probably do this for you. Here's a nice summary of some of the clustering methods available in 'R' - it looks like the density clustering is what might work for you.
Have a look at Helmoet's PointClusterer custom transformer. It takes the number of groups as a parameter, but it can proabaly be adapted to your requirements.
I think if you included a sample dataset you might find some community members who would like to pickup the challenge...
Thanks by that, I am reading and learning a lot because this need to be my next step (R or Python clustering), but not found yet clustering with max number of points per cluster and/or maximum distance, only minimum points and/or maximum distance. I got my result using NeighborFinder, but in manualy way, I cluster the firsts points and they get out of my analysis them I go ahead with the rest data and next NeighboorFinder, as I said, my data is small so this is possible, but I needed to create more than 50 neighborhoodfinder transforms and the result is ok, I can go through this way, its not the best fit, but it is acceptable.
My problem now is that I need to change the parameters and it´s not easy to change parameters of 50 neighboorfinder and with I change the distance and numbers of neighboor to find, I need to change the number of interactions, in that case I will reduce the number, so I gonna need more neighboorfinders interacions. So Looping into my NeighborFinders until my data is over is my goal, but it´s being quite impossible. I have made it perfect to my eyes and I got this answer "
f_12 (TransformFact): Custom transformer 'NEIBA' does not have a port named 'Input_2' which is suitable for parameter 'LOOPBACK_INPUT_TAG'
Custom transformer 'NEIBA' does not have a port named 'Input_2' which is suitable for parameter 'LOOPBACK_INPUT_TAG' "
But I have this port, but it´s not published (because I need the attributes from the last interaction). If I make thhis port visible (Published), my process go ahead, but it´s never end.
Because of necessity of transform qualification as Linked Always, I can´t see where the problem is. I am very frustated that I can´t make a simple loop with a block transform.
@rodrigo_ferrao Creating Custom Transformers with looping and blocking transformer like NeighborFinder is not easy. That is why I would suggest looking at other 3rd party options for a problem like this that needs a recursive or iterative algorithms.
For NeighborFinder, you could use Published Parameters to set the values in the different NeighborFinders
Yes, I made it by parameter, but if I want to put less points in my group, I will need more interactions in that case, more neighboorfinders (so need to put more transforms not only set values), a loop will kill this problem. Put I don´t know what is wrong, can I put my loop .fmx here? Is that possible?
I have JUST finished my looping! The problem was that I need to use variable setter before de looping exit and loop to the input. It´s now clear to me and I´am very happy with it, I love FME hahaha! Thanks by the help I will mark your first answer as right, because R and Python are the key to achieve a perfect clustering.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
