I am using a sorter in 2019.0 right after a FeatureJoiner. I have two fields where all the values are changed after the Sorter. I create the fields using the sub() function in an AttributeManager before the join and sort. Many of the values are null. On the other side of the Sorter they're numeric with a maximum of 255 (telling). Anyone else observed this? If I run the Sorter prior to the Joiner I do not see this error. I'm sorting on a couple of other fields, and neither of the fields that are being updated.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
