Open
Add a 'Case sensitive' Option to the Joiner
Related products:Transformers
rylanatsafe
siennaatsafe
jdh
+22
  • rylanatsafe
    rylanatsafe
  • siennaatsafe
    siennaatsafe
  • redgeographics
  • takashi
  • jdh
    jdh
  • lifalin2016
    lifalin2016
  • tcrossman
    tcrossman
  • carmijo
    carmijo
  • oscard
    oscard
  • stalknecht
    stalknecht
  • lars_de_vries
    lars_de_vries
  • jelle
    jelle
  • geosander
    geosander
  • arnovananrooij
    arnovananrooij
  • kennyo
    kennyo
  • gbj1717
    gbj1717
  • revesz
    revesz
  • jpsalva
    jpsalva
  • toin
    toin
  • nedrich207
  • senteria
  • dwhitworth-cop
  • roland.martin
    roland.martin
  • michaelbreen
    michaelbreen
  • candacel
    candacel
  • geertrui
  • elavine
lars_de_vries
Add a 'Case sensitive' option to the Joiner. Sometimes capitalization of attributes differs between source and target attributes. It would be nice if you could just use an option to take this into account or not.
geosander
Forum|alt.badge.img+7
  • November 10, 2015
Yes, this is a great idea. In fact, I think this should be an option for a lot of transformers where strings are being compared (e.g. Tester, TestFilter, AttributeValueMapper...). Sometimes, I don't care how FME compares values, but I do need to keep the original writing style. Now I need to copy the old value and apply an @LowerCase() function or StringCaseChanger, which clutters my workflow a little.
  • June 23, 2016
I had the same idea for the featuremerger,...
rylanatsafe
Forum|alt.badge.img+13
See also Idea: 'Case Sensitive' option when testing attribute values.
oscard
Forum|alt.badge.img+21
  • January 16, 2018
Having that option in the FeatureMerger (or any other transformer with similar functionality) would be a charm!
Yesterday, I had to deal with un unexpected change of case that nobody told me about.
jdh
Forum|alt.badge.img+28
  • December 10, 2018
The Tester now has Case Sensitive, Case Insensitive options in the Comparison mode. It would be nice if the FeatureMerger/Feature joiner could do so as well.
