How do you make an automation with two workspaces use only one engine?
  • October 19, 2022
  • 4 views
u12runm
Forum|alt.badge.img+4
hkingsbury
Forum|alt.badge.img+51
  • October 24, 2022
I think what you could do, is create a Job Routing Rule for the two workspaces so they are on the same queue. Then create a rule to assign one engine to the queue
