how to output python script result to use in FME?
  • May 11, 2020 9:55 AM UTC
  • 7 replies
  • 770 views
I use python caller to get data from json into FME desktop.
Through few steps in Python, I exctract the data that I need and add it to a python dictionary.  Basically this dictionary contains pairs of plan numbers (Unique Identifier) & coordinates for polygons (python list).
The last few lines of my code are :
    plans_dict = dict()
    for each in campuses['campuses'][0]['sitePlanMetadata']['spatialMetadata']['planFootprints']:
        # creating dictionary with plancode as key and polygon coordinates as values
        plans_dict[each['planCode']] =  each['polygons']['coordinates']
Then I tried to  output the dictionary to my FME workbench to use the data in the next step, which is create a spatial dataset containing the polygons:
output = plans_dict
feature.setAttribute("output", output)
I get an error:
Python Exception <TypeError>: Could not convert attribute value to a supported attribute type.
Error encountered while calling function `processFeature'
PythonCaller (PythonFactory): PythonFactory failed to process feature
What is the way to output my data from python caller to FME workbench?
  • May 11, 2020 10:08 AM UTC
The setAttribute() method doesn't know what to do with Python dicts, as there are no corresponding datatypes in FME.
Basically, you'll have to do some pre-processing to e.g. iterate over the dict and only send integers, floating point numbers or text strings to setAttribute().
General example:
my_dict = {'key1': 'value1', 'key2': 'value2'}
for key, value in my_dict.items():
    feature.setAttribute(key, value)
The output will be a feature with the following attributes:
Attribute 'key1' with value 'value1', and attribute 'key2' with value 'value2'
  • May 11, 2020 10:56 AM UTC
General example:
Thank you david_r.
I am not very experienced with FME. Just know it can do nearly everything ;)
I know that i need to set attribute to expose to be able to get the value with FME. What do I need to expose after running you code? Feature?
And value in my dictionary is also a list. I just ran it again, and FME wasn't happy about it either :(
Forum|alt.badge.img+54
  • May 11, 2020 11:02 AM UTC
If your dictionary contains lists, what are you hoping to have as an output
- a feature with the key attribute and a list of all the values
- a feature for each list value also containing the key attribute
  • May 11, 2020 11:05 AM UTC
Second option: a feature for each list value and also containing the key attribute.
List is a list of coordinates that makes a polygon and key attribute is basically a name for polygon.
  • May 11, 2020 11:11 AM UTC
A list of tuples/coordinate pairs? This is all possible with python, but i think there may be better ways to do this in FME if the input data is JSON
  • May 11, 2020 1:32 PM UTC
If all the dictionary values contain lists, you can use FME attribute lists, although you still need to make sure that the list elements are either integers, floats or strings. Example:
my_dict = {'key1': [1,2,3], 'key2': [4,5]}
for key, values in my_dict.items():
    for n, list_value in enumerate(values):
        feature.setAttribute('my_list{%s}.%s' % (n, key), list_value)
You should then expose "my_list{}.key1" and "my_list{}.key2" in the PythonCaller, so that you can e.g. use the ListExploder later on with the FME list.
The output would be one feature with the following list elements:
my_list{0}.key1 = 1
my_list{1}.key1 = 2
my_list{2}.key1 = 3
my_list{0}.key2 = 4
my_list{1}.key2 = 5
  • May 11, 2020 1:51 PM UTC
This code will create one feature for each key in the dictionary, with a polygon composed of the vertices in a list containing (x,y) coordinate tuples:
import fmeobjects
class CreatePolygons(object):
    def __init__(self):
        pass
    def input(self, feature):
        # Test polygon
        my_dict = {'poly1': [(0,0), (1,1), (1,2)], 'poly2': [(5,5), (5,6), (6,5), (5,5)]}
        # Iterate over the dictionary items
        for polygon_name, vertices in my_dict.items():
            # Create an empty output feature
            new_feature = fmeobjects.FMEFeature()
            # Set the polygon_name attribute
            new_feature.setAttribute('polygon_name', polygon_name)
            if vertices[0] != vertices[-1]:
                # Close the polygon, if necessary
                vertices = vertices + [vertices[0],]
            # Set the geometry based on 'vertices'
            new_feature.setGeometry(fmeobjects.FMEPolygon(fmeobjects.FMELine(vertices)))
            # Output the new feature
            self.pyoutput(new_feature)
    def close(self):
        pass
Expose the attribute name "polygon_name".
You may want to consult the API documentation to fully understand the code: https://docs.safe.com/fme/html/fmepython/intro.html
