Sperate Columns
  • Oct 13, 2022 7:00 AM UTC
  • 12 replies
  • 69 views
asadamjad
Participant
Forum|alt.badge.img+12
I have excel file where i need to separate all columns please help me out
Forum|alt.badge.img+63
That looks like JSON, so a JSONFragmenter / JSONFlattener would be the way to go.
asadamjad
Participant
  • Participant
  • Oct 13, 2022 7:08 AM UTC
i have data in Excel
asadamjad
Participant
  • Participant
  • Oct 13, 2022 7:10 AM UTC
how can i seprate them
Yes, the data is in Excel.
But the content of the attribute locations_affected is encoded in JSON. So if you use a JSONFragmenter on that you can pull it apart to separate attributes:
Screenshot 2022-10-13 at 09.12.38
asadamjad
Participant
  • Participant
  • Oct 13, 2022 7:17 AM UTC
okay how can i expose the values and write in Excel file
Have you tried the Attributes to Expose parameter in the JSONFragmenter? The downside of that is that you need to know the attribute names.
asadamjad
Participant
  • Participant
  • Oct 13, 2022 7:21 AM UTC
why geometry is in sepetr row
That's how the JSON is structured, you'll need to ask whoever designed that. However, the xlsx_row_id has the original row number from Excel so you can still match up all the data. It does look like there's multiple objects (2 it seems) per Excel row. That makes me think you really need some background information on this dataset to make informed decisions. Again that's something you need to check with whoever is supplying the data.
asadamjad
Participant
  • Participant
  • Oct 13, 2022 7:41 AM UTC
I did this how can i bring json_index in columns
Honestly, I think you've maybe gone one step too deep into the JSON (that's controlled by the number of [*] in the JSONFragmenter) and one step higher would yield more useable results.
Without seeing your workspace, knowing what you have already tried or knowing what you want to do exactly it's hard to give you good advice.
asadamjad
Participant
  • Participant
  • Oct 13, 2022 8:40 AM UTC
Please find the attached
Have you tried [*][*] in the JSONFragmenter (like I initially did and hinted at with my last answer) and if so, why did that not yield the results you want?
Please note that on a forum like this people are sharing their knowledge freely, but do so either on their own time or by taking time out of their work day. A good way to acknowledge that is to show commitment by providing the information needed to answer your question and to also try things yourself. We want you to learn FME, but the best way you can learn it is by actually doing it yourself, by experimenting (and sometimes failing).
I can't help you any further today, I need to work on other stuff.
