Silly question, but how do you join one to many in a spatial format?
  • Jun 14, 2021 3:14 PM UTC
  • 149 views
mjones
Participant
I have a list of permits joined to address points. About 100k points after that join. I want to join those 100k to the parcels which have about 40k so there would be some parcels that are 'stacked' and have 5 rows. I'm trying SpatialFilter, SpatialRelator and PointOnAreaOverlayer and not having any luck. I'm using 2021.0 desktop.
itsmatt
Forum|alt.badge.img+48
  • Jun 15, 2021 7:02 AM UTC
What you need to do is use the list option (on the areas) when merging attributes when using the PointOnAreaOverlayer. You can then use a ListExploder which will create one feature for each element in the list.
Example
