Overwriting Coordinates 0 + 1 of a line with information from attributes
  • Oct 10, 2023 2:26 PM UTC
  • 69 views
renetschi
Forum|alt.badge.img+4
Hello everybody,
i have a question regarding lines:
i have a network of lines in 2D. The information of the z value is stored in 2 different attributes: height1 and height2. I would like to add the height1 to the coordinate0, and would like to add the height2 to the coordinate1 of the line.
So far i tried some ways but could not figure out how to overwrite the coordinates of the line.
any help would be very appreciated.
thanks a lot
rené
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to explode the lines to points, recreate the points but now with height, recreate the lines from points.
nielsgerrits
Added workspace demonstrating this.
  • Oct 10, 2023 3:13 PM UTC
The VertexCreator has a mode "Replace point at index" to replace individual vertices. If you need to keep the X and Y and only replace the Z, you could use a CoordinateExtractor first.
renetschi
  • Oct 11, 2023 1:20 PM UTC
hey david and niels,
thank you so much for your quick replies and your help!
i implemented the workflow from RebuildLines3D. it worked great for all lines with just two vertices. if lines come up with curves i am struggling with this situation a bit. so i will think about a solution here.
i also tried the VertexCreator with the mode "Replace point at index" wich worked really great for me. Maybe i will continue with this option.
Again thank you so much for your help. This saved me a lot of time!
Best regards
René
