.obj files and fme - accessing the points
  • Oct 14, 2016 6:44 PM UTC
  • 125 views
Hi
First time using .obj files and i can build the mesh as a single item. How would i go about access each individual point geometry? I have tried a few things i could think of but nothing worked.
Anyone know much about obj files?
thanks
  • Oct 15, 2016 12:12 AM UTC
Hi @lemzip, I can provide two ways to extract every vertex point from a Mesh geometry.
TINGenerator: Send the Mesh feature to the Points/Lines port of a TINGenerator, set 0 to the "Surface Tolerance" parameter, and then pick the Point features output from the VertexPoints port.
Or,
PythonCaller with this script.
class FeatureProcessor(object):
    def input(self, feature):
        mesh = feature.getGeometry()
        for i, xyz in enumerate(mesh.getVertices()):
            feature.setGeometry(fmeobjects.FMEPoint(*xyz))
            feature.setAttribute('_vertex_id', i)
            self.pyoutput(feature)
  • Oct 16, 2016 6:50 PM UTC
Or,
@takashi, Thanks i can now pull out the vertex.
Another question, the vertex x,y, and z in the file in plain text is like this:
v  11416.5 -0.00023741 -5431.3
v  11422 -0.000238869 -5464.68
v  11357.1 -0.000239796 -5485.89
v  11379.5 -0.000241047 -5514.52
v  11379.1 -0.000239044 -5468.68
Is that in any relation to a spatial projection etc or is it just the location in the file?
I cannot find anywhere in the file that gives me any indication on spatial reference used.
itay
Forum|alt.badge.img+19
  • Oct 16, 2016 8:27 PM UTC
v 11416.5 -0.00023741 -5431.3 v 11422 -0.000238869 -5464.68 v 11357.1 -0.000239796 -5485.89 v 11379.5 -0.000241047 -5514.52 v 11379.1 -0.000239044 -5468.68
I don't think the obj supports any spatial projection and that it is all relative location.
itay
  • Oct 17, 2016 7:54 AM UTC
Digging further into the documentation revels the possibility to move the data into world coordinate systems when reading, but it requires the 'companion' dataset files (??)
