I would like to import multiple xlsx files into a single Geodatabase.
  • Oct 27, 2021 8:01 AM UTC
  • 89 views
I am working on creating a geodatabase made up of multiple types of proformas, a total of 67 different proformas. The proformas contact collected survey data of differing species and spatial data.
itsmatt
Forum|alt.badge.img+48
  • Oct 27, 2021 10:49 AM UTC
to get you started here is an article on getting started with Excel in FME:
https://community.safe.com/s/article/getting-started-with-excel-2
And another one on Converting to geodatabase:
https://community.safe.com/s/article/writing-to-geodatabase-various-formats-to-geodatab
A lot of the rest of the workflow will be up to how your input data is structured and how you want your output to look.
To create geometries from x and y's (or lat/long) you can use a tool called the VertexCreator. This will create points.
  • Oct 27, 2021 3:25 PM UTC
Thanks very much for responding.
I have gone through countless forums now and cannot seem to find the specific issue I am facing.
I think the process should be involve proformas -> collating/merging into multiple entries on a single file-> inputing the combined proformas into a geodatabase.
Do you know of any further information I could use please
