I want Download from web
  • Jun 24, 2022 7:13 AM UTC
  • 17 replies
  • 91 views
asadamjad
Participant
Forum|alt.badge.img+12
I create the workspace but problem is its getting first one but what i need is get the latest one.
also the file is KMZ and i cant get the Placemark where all location is stored please help me out in this
https://www.nhc.noaa.gov/gis/
I am attaching the workspace
Best answer by redgeographics
how can i get only current year Storm
Once you have the year in a separate attribute you can use a TestFilter to do that, like this:Schermafbeelding 2022-06-27 095809
Forum|alt.badge.img+63
Your StringSearcher is only returning the first match, but there are many. If you check in its parameters you can set a "all matches list name" under the Advanced section, do that and you'll get a list of, in this case, 88 matches.
I'm not familiar with the naming convention of these files though, so I'm not entirely sure which would be the latest one.
Then as for the KMZ placemarks, the FeatureReader is reading a dynamic filename, so when you're designing the workspace it doesn't actually know what that file is like. You can work around that by downloading one of the files first and use that to develop the workspace, then switch it back to a dynamic filename when you're done. Alternatively, you can manually specify which output port(s) you want it to have.
asadamjad
Participant
  • Participant
  • Jun 24, 2022 7:51 AM UTC
asadamjad
Participant
  • Participant
  • Jun 24, 2022 7:53 AM UTC
there are datasets and each dataset have storm in each area
like Atlantic Eastern Pacific Central Pacific
in each storm file name AL012022_017adv_most_likely_toa_34.kmz
only chnage is 012018
022018
each storm have numbers after Area alpha code and year so i need by numbers and current year
asadamjad
Participant
  • Participant
  • Jun 24, 2022 7:54 AM UTC
I am new in FME please help me Out
So...
AL01 = Atlantic
2022 = year
and then they're numbered consecutively?
asadamjad
Participant
  • Participant
  • Jun 24, 2022 8:03 AM UTC
Yes ..
So Atlantic = AL
Eastern Pacific  = ep
Central Pacific - cp
so each area will be seprate work space
asadamjad
Participant
  • Participant
asadamjad
Participant
  • Participant
  • Jun 24, 2022 8:04 AM UTC
Ep have three storm till now so they give the numbers how many storm have in that area
asadamjad
Participant
  • Participant
  • Jun 24, 2022 8:06 AM UTC
and one more thing
this KMZ file should convert from KMZ to Shapefile..
But in the matches list I see a different naming structure:
AL312020_most_likely_toa_34_latest.kmz
What you can do, once you have that naming structure clear, is:
  • Use an AttributeCreator to create region, year and number attributes using the SubString fuction
  • Sort by year and number
  • Use a Sampler, grouping by region, to get the last storm.
asadamjad
Participant
  • Participant
  • Jun 24, 2022 8:17 AM UTC
Sorry i gave you wrong file name
AL312020_most_likely_toa_34_latest.kmz (This one is correct)
as i said i am new on FME
asadamjad
Participant
  • Participant
  • Jun 24, 2022 8:19 AM UTC
problrm is i am not able to get the latest storm from web
Have you tried to follow the steps I outlined above?
Schermafbeelding 2022-06-24 103046This should do the trick for getting the last storm.
asadamjad
Participant
  • Participant
  • Jun 24, 2022 9:25 AM UTC
Its work but problem is there is data as well under the document when i get placemark and document everything working fine but whn i load to Arcgis portal i get the data but not placemark why is that
asadamjad
Participant
  • Participant
  • Jun 24, 2022 9:28 AM UTC
asadamjad
Participant
  • Participant
  • Jun 24, 2022 3:50 PM UTC
