I have created a custom coordinate system (cs) with the online tool. My cs is in the correct folder (c:\\user\\xxx\\Documents\\FME\\CoordinateSystems), I can see it in the menu Tools-Browse Coordinate system... , I can transform some points but when
  • Dec 1, 2021 2:52 PM UTC
  • 103 views
I export a shape file, the prj file includes only this: PROJCS [ "MAGNA-SIRGAS / Origen-National" which is the name of my cs. What I have to do to have a correct prj file?
daveatsafe
Forum|alt.badge.img+24
  • Dec 2, 2021 10:10 PM UTC
If you included an Esri WKT string when defining your coordinate system, please open the .db file in your c:\\user\\xxx\\Documents\\FME\\CoordinateSystemExceptions folder that matches your cs file data in a text editor. Check that the WKT is complete, and contains no carriage returns.
If you did not include an Esri WKT string when creating your coordinate system, please create a new .db file in that same folder with the following content:
ESRI|<your coordinate system name>|<Esri WKT with no carriage returns>
The .db file contents map your custom coordinate system to an Esri WKT string that is used whenever you write to an Esri format.
arnold_bijlsma
Forum|alt.badge.img+16
Hi ​@daveatsafe
Is there any further documentation on CoordinateSystemExceptions, as the only link I can find is in this article, but it’s dead :-(
daveatsafe
  • Feb 9, 2026 4:48 PM UTC
Hi ​@arnold_bijlsma,
Thanks for alerting us to the dead links in that article. We will be updating those shortly.
