How to limit the decimals in the result of the lengthcalculator ?
  • Oct 9, 2020 12:30 PM UTC
  • 150 views
Hello,
I have a shp layer of lines for which I need to calculate the length of each line then round it to suppress the decimals.
I use the lenghtcalculator to get the lenght of each line but for some lines I get results such as 7.566995918750763e-10 or 1.7276990785794134e-9
With these results, I get 0 after the attributerounder. I even tried a stringformatter to reduce the amount of decimals but theses objets also turn into 0.
Is there a way to avoid getting so much precision when calculating the lenght ? Or another way to calculate the lenght (I get the same result with an attribute creator and length() ) ?
Many thanks in adance!
Ann
Best answer by david_r
7.566995918750763e-10 (scientific notation) is the same as 0.0000000007566995918750763, so unless you round down to more than 9 decimals the result is actually going to be 0.
I'm guessing these are extremely short line segments?
  • Oct 9, 2020 12:41 PM UTC
Forum|alt.badge.img+54
  • Oct 9, 2020 12:44 PM UTC
What distance units are you working in, 7.566995918750763e-10 is a very small number which is why it rounds to zero
  • Oct 9, 2020 1:20 PM UTC
Thank you very much. I understand better what it means, it is logical that it rounds to 0. Indeed these are extremely short lines. Thanks!
