How to generate TINrelief of CityGML from TIN generated by TINgenerator
  • Sep 25, 2020 1:47 PM UTC
  • 205 views
I generated TIN by TINgenerator.
I would like to procedure to generate TINrelief of CityGML from the TIN.
daveatsafe
Forum|alt.badge.img+24
  • Oct 2, 2020 10:41 PM UTC
Hi @bigapplerizzi19​ ,
Please send the TINSurface output of the TINGenerator to a CityGMLGeometrySetter transformer, with CityGML Lod Name set to 'tin' and Feature Role set to 'reliefComponent'. Output to the CityGML TINRelief feature type.
I am attaching a workspace to illustrate the process.
Hello daveatsafe,
Thank you for your reply and sending the workspace.
I will try to the procedure in a few days.
Best Regards,
Hello @daveatsafe​
I could generate TINrelief of CityGML from TIN generated by TINgenerator according to your procedure.
Thank you for your help.
model_art
  • Jan 28, 2025 9:55 AM UTC
Could you please share the workspace file?
