Hi!, How to create geometry from x,y coords received in .shp file? we need to migrate these coordinates as geometry in smallworld. Thanks
  • Dec 8, 2021 5:55 PM UTC
  • 97 views
nag
hkingsbury
Forum|alt.badge.img+73
  • Dec 8, 2021 7:04 PM UTC
Theres a couple of options, if the coordinates are stored in a 'standard' format (eg GeoJSON, OGC) Then have a look at the GeometryReplacer.
If they're not then you'll need to use the VertexCreator. If they're points, then its pretty straight forward, however if the desired geometry is a line or polygon, you're going to have to break down the data to the individual coordinate pair, then recreate the desired geometry from the vertices
danilo_fme
Forum|alt.badge.img+58
  • Dec 9, 2021 12:16 AM UTC
Nice job!
milo89
Forum|alt.badge.img+26
  • Dec 14, 2021 11:44 PM UTC
When writing to smallworld you should inspect the data beforehand to find out the geometry configuration. I understand there are differences in Smallworld 5.x but the methods for Smallworld 4 still work in Smallworld 5.
As such, you should look to find the below attributes and ensure these are populated for the data you're writing to Smallworld along with setting fme_db_operation.
sworld_attributesFurther information that might prove useful:
Importing into Smallworld
Writing to Smallworld Multiple Geometries
