FME won't write to Azure writer with no primary key
  • Apr 8, 2022 5:41 AM UTC
  • 139 views
I am trying to write from Excel to Azure. The writer table has no primary key as it is just a staging table and doesn't need one. FME will not allow me to write to it unless I set a primary key. Azure lets me write to the table within the server so it seems like it is only FME requiring a primary key. How do I get FME to write to a writer with no primary key?
This is the error message (I am not creating a new table):
Microsoft SQL Server Non-Spatial Writer: Failed to create Azure table 'dbo.test_survey' because no clustered index or primary key was specified. If creating a new table, go into the 'User Attribute' tab and set the 'Index' column to 'clustered', 'clustered_not_null', or 'primary_key' for a column
And these are the settings
settings
rahulsharma
Forum|alt.badge.img+12
Hi @clare123​
This appears to be by design, I can definitely check with our dev team.
Can I request you to modify your workspace to use Microsoft Azure SQL Database Non-Spatial (JDBC) writer instead?
As per my testing, this writer appears to be working as expected.
