Fanout oder Dynamic write anhand clipper
  • Aug 2, 2022 10:05 AM UTC
  • 19 views
arash_hokm
Forum|alt.badge.img+8
I have 16 polygons (zone) and a feature of points. I would like to clip points by zone and write to points in each zone in a separate shapefile. that means as a result I have to get 16 shapefile from points. Attached you can see the workbench
I tried dynamic and fanout. anyway i only get one feature from punkt.
Clipper
geogaard
Forum|alt.badge.img+15
  • Aug 2, 2022 11:57 AM UTC
Hi, you need to merge attributes in the Clipper and then you can fanout by the name of the zone.
