Balcony thickness calculate
  • Sep 8, 2021 11:54 AM UTC
  • 5 replies
  • 93 views
ienesaglam60
Forum|alt.badge.img+3
balcony_thicknessI have balcony drawings as attached files two sample data. I want to calculate the thickness of the balconies as seen in the picture. is there a transformer for that?
Best answer by nielsgerrits
Added sample workspace.
I would exclude short lines from the analysis. Shorter than 0.3m worked fine for your samples. But feel free to experiment what works best yourself.
  • LengthCalculator after the Chopper
  • Tester after the LengthCalculator, _length > 0.3
2021-09-08_14h53_03
nielsgerrits
Forum|alt.badge.img+67
I can think of a way, success depends on the complexity of the geometry. Explode the polylines into lines, get the midpoints from the lines and find the closes lines, not the source line itself.
  • Chopper to create lines with 2 vertices.
  • CenterPointReplacer to convert to midpoints.
  • NeighborFinder to find closes lines to points. Number of Neighbors to find = 2. Generate Closest Candidates List.
  • ListExploder to go from list to features.
  • Tester to remove all results with _distance = 0, these are the original lines.
  • Now you have multiple widths. You can draw those using VertexCreators and the closest_base / closest_candidate attributes.
nielsgerrits
ienesaglam60
  • Sep 8, 2021 12:41 PM UTC
Thank for attention. But it also works on balcony corners and i don't want that. Can you use the examples i attached?
nielsgerrits
  • Sep 8, 2021 12:53 PM UTC
2021-09-08_14h53_03
ienesaglam60
  • Sep 8, 2021 1:14 PM UTC
This looks like it is works . Thank you
