Writing relationships in ESRI file geodatabase
  • May 22, 2013 6:21 PM UTC
  • 265 views
All,
I am using the ESRI file geodatabase writer to write data to both a feature class and table class and establish a foreign key relationship between the data in the two classes.  The only relationship documentation I've found is under the ESRI geodatabase (Access database) writer and that is what I have been trying.
I have three FME feature types for my writer;  one for the feature class, one for the table class, and one for the relationship.  I am setting a geodb_oid on the data for the feature class and table class.  I am setting the set the geodb_type to geodb_relationship, and I've also tried geodb_attributed_relationship, on the relationship FME feature type.  The geodb_feature_has_relationship is set to Yes for all three FME feature types and the geodb_rel_origin_oid and geodb_rel_destination_oid are being set for just the relationship feature type.
When I run the workspace, I'm receiving the error:
Attempting to write a non-relationship feature to relationship class 'Main_Liner'. Ensure the 'geodb_type' is set to a valid relationship class type
Am I doing something wrong or is the ESRI file geodatabase writer not able to write the relationship information?
Thanks,
Steve
fmelizard
Forum|alt.badge.img+22
  • May 22, 2013 7:18 PM UTC
This should be possible as this demo shows.
I would test the geodb_type attribute to make sure the correct values exist.
Hope this helps.
  • May 22, 2013 11:41 PM UTC
Thanks for the response.  I wasn't setting the geodb_type attribute correctly.
andystreet
Participant
  • Participant
  • Mar 26, 2015 7:21 AM UTC
I'm, getting the same response writing a relationship to a GEODATABASE_MDB relationship class. I have checked the relationhsip feature and it has the attributes I believe are needed. i.e.
geodb_rel_destination_oid (64 bit integer)    2
geodb_rel_origin_oid (64 bit integer)    1
geodb_type (string)    geodb_relationship
In your initial question it looks like you were setting the geodb_type attribute correctly initially, but then you indicate in the resolution that some other geodb_type setting was needed.
Do you recall what the change to geodb_type then allowed the relationship to be created?
I've checked the demo and the answer didnt jump out at me.
Thanks andy
blueinc
  • Jul 13, 2015 9:46 PM UTC
@AndyStreet: In addition to the 3 attributes you mention, I also had to set geodb_feature_has_relationships = YES (using an AttributeCreator) and set the Allowed Geometries on the Writer feature class = geodb_relationship
