Which parameters in FME will enable the display and sorting capability based on the "alias" field in a shapefile?
  • Oct 10, 2017 12:27 AM UTC
  • 97 views
  • Oct 10, 2017 7:19 AM UTC
What do you mean by an "alias" field? Can you provide a screenshot?
  • Oct 10, 2017 9:05 PM UTC
Thanks David. I have been able to rename the attributes using the AttributeRenamer transformer in FME but ideally I would like to import the attributes directly from an ESRI shapefile using the alias field (screen shot attached)
dustin
Forum|alt.badge.img+36
  • Oct 10, 2017 11:41 PM UTC
@kirsten I think the alias option is only available in an ESRI Geodatabase, not in shapefiles.
This tutorial may be of some help: https://knowledge.safe.com/articles/22423/working-with-geodatabase-field-aliases.html
gio
Forum|alt.badge.img+15
  • Oct 11, 2017 11:03 AM UTC
Alias is also available using shapes. (I often do this, when I'm too lazy to reprocess the data...). Mostly when creating map-books with queries and map-queries for output.
But you can't access it trough a shape reader because afaik it is not information in the shape file but in the mxd.
So as per @cartoscro hint, you'll need to save the data into a geodatabase wich would make it accessible trough the gdb reader.
